How to Extend - add localization to mononobehavior
8 years 4 months ago #3141 by tcwicks
Whats the best way to extend this. So for example I have a UIToolTip class. I want to make that localizable by I2Localize
Looks like you have ILocalizeTargetDescriptor and ILocalizeTarget
So I'm assuming that by either adding descriptiors or supporting an interface I can make the target class localizable.
Could you give me a pointer on what I should do for a monobehavior to make I2 Localize pick it up as a translation target
Kind Regards
Tikiri
8 years 4 months ago #3142 by Frank
Its quite simple, You need to create a LocalizeTarget class that does the localization, and a descriptor that its used in the editor to show all localized targets and prioritize them.
The following example, adds support for localizing the UIToolTip class with a string UIToolTip.tooltipText
Just create a new script named LocalizeTarget_UIToolTip.cs with the following code:
namespace I2.Loc
    #if UNITY_EDITOR
    [UnityEditor.InitializeOnLoad]
    #endif
    public class LocalizeTarget_UIToolTip : LocalizeTarget<UIToolTip>
        static LocalizeTarget_UIToolTip() { AutoRegister(); }
        [RuntimeInitializeOnLoadMethod(RuntimeInitializeLoadType.BeforeSceneLoad)]
		static void AutoRegister()
			LocalizationManager.RegisterTarget(new LocalizeTargetDesc_Type<UIToolTip, LocalizeTarget_UIToolTip>()
				Name = "UI ToolTip",
				Priority = 100
        public override eTermType GetPrimaryTermType(Localize cmp) { return eTermType.Text; }
        public override eTermType GetSecondaryTermType(Localize cmp) { return eTermType.Text; }
        public override bool CanUseSecondaryTerm() { return false; }
        public override bool AllowMainTermToBeRTL() { return true; }
        public override bool AllowSecondTermToBeRTL() { return false; }
        public override void GetFinalTerms ( Localize cmp, string Main, string Secondary, out string primaryTerm, out string secondaryTerm)
            primaryTerm = mTarget ? mTarget.tooltipText : null;
            secondaryTerm = string.Empty;
        public override void DoLocalize(Localize cmp, string mainTranslation, string secondaryTranslation)
			mTarget.tooltipText = mainTranslation;
That will register automatically on startup.
The GetFinalTerms allows inferring the term name from the UITooltip text.
The DoLocalize applies the translation.
8 years 4 months ago - 8 years 4 months ago #3143 by tcwicks
Hi Frank
Thanks much for that.
Also some variant of the following extension could be packaged with i2 Localize such that people could use an Enum rather than string keys when accessing translations from code
        public static string LocalizedEnumText<T>(this T TermKeyEnum, string Default)
            where T: struct
            if (!typeof(T).IsEnum) throw new ArgumentException("T must be an enumerated type");
            string Key;
            Key = Enum.GetName(typeof(T), TermKeyEnum);
            if (string.IsNullOrEmpty(I2.Loc.Localize.MainTranslation))
                return Default;
            string Result;
            Result = I2.Loc.LocalizationManager.GetTermTranslation(Key);
            if (string.IsNullOrEmpty(Result))
                //UnityEngine.Debug.Log(string.Concat(@"Translation not found for Key: ", Key));
                return Default;
            return Result;
So For example if using a non generics based method coupled with a specific enum
//usage example
// UITerm.term_initial_mission_energy.Translate(@"Initial Mission Energy");
        public static string Translate(this UITerm Term, string Default)
            string Key;
            Key = Enum.GetName(typeof(UITerm), Term);
                return Default;
            string Result;
                return Default;
            return Result;
Last edit: 8 years 4 months ago by tcwicks.
8 years 4 months ago - 8 years 4 months ago #3144 by Frank
There is already a built-in way of accessing translations without using strings:
inter-illusion.com/assets/I2Localization...riptsforsaferac.html
Just bake the terms, and instead of doing
string text1 = I2.Loc.LocalizationManager.GetTermTranslation("Tutorial/Tittle");
You can do:
string text1 = I2.Loc.ScriptLocalization.Tutorial.Tittle;
Last edit: 8 years 4 months ago by Frank.
8 years 4 months ago #3145 by tcwicks
Thansk Frank
Facepalm - RTFM - LOL
:ohmy:
