Error in Documentation
8 years 5 months ago #3098
by textman
Error in Documentation was created by textman
I wanted to report a possible typo in the documentation for I2 Localization.
On this page:
inter-illusion.com/assets/I2LocalizationManual/AssetsTab.html
Currently it says:
It should be corrected to include the word "not":
On this page:
Currently it says:
When the asset is inside the Resources folder or an AssetBundle, I2 Localization can load them at runtime using the asset path and name.
However, when it is located in the project (but in the Resources folder), the plugin has to keep a reference to the asset and use that at runtime.
However, when it is located in the project (but not in the Resources folder), the plugin has to keep a reference to the asset and use that at runtime.
8 years 5 months ago #3101
Replied by Frank on topic Error in Documentation
Thanks for pointing that out!
I will fix it right away!
