Null reference when changing password of webapp
- BinarySouls
8 years 5 months ago - 8 years 5 months ago #3085
by BinarySouls
Null reference when changing password of webapp was created by BinarySouls
Version: 2.8.6 f2
(Also tested on a fresh project)
When creating a web app, if you change the password that says "change_this", when clicking on Refresh or New after validating the web app, it returns "Object reference not set to an instance of an object".
Commenting out the entire "wrong password" (the following code) check of the web app makes that error to not appear:
if (LocalizationPassword!="change_this" && (action=="GetSpreadsheetList" || action=="NewSpreadsheet" || action=="SetLanguageSource") &&
e!==undefined && e.parameters.password!=LocalizationPassword)
return ContentService.createTextOutput("Wrong Password").setMimeType(ContentService.MimeType.TEXT);
Last edit: 8 years 5 months ago by BinarySouls.
8 years 5 months ago #3086
Replied by Frank on topic Null reference when changing password of webapp
Changing the password feature requires 2.8.7b3 or higher.
inter-illusion.com/forum/i2-localization...ty?limitstart=0#3064
That version can be downloaded from the beta folder. I plan on uploading it to the AssetStore by the end of the week.
In the meantime, the password shouldn't be changed in the WebService (i.e. it should be kept as "change_this" so that it gets ignored).
I understand that's confusing, so I just placed a comment in the WebService to avoid further confusion until 2.8.7 is in the AssetStore.
The following user(s) said Thank You: BinarySouls
Time to create page: 0.126 seconds
