Chinese simplified and traditional dialects
8 years 5 months ago #3050
by enghoff
Chinese simplified and traditional dialects was created by enghoff
Neither I2 nor Unity nor Google regional language codes do to my knowledge pick up on the Chinese dialect setting (simplified vs traditional) on Android, which is an issue on some devices that provide dialect options separately from regional settings. Does anyone know of any possible means of extracting the chosen dialect setting on Android?
8 years 5 months ago #3051
Replied by Frank on topic Chinese simplified and traditional dialects
I2 Localization is able to detect the region you setup in your device.
It has code in Assets\I2\Localization\Scripts\Manager\LocalizationManager_SystemLanguage.cs function DetectDeviceLanguage() to get the language name and region using the Android SDK.
If that fails, the plugin uses the Unity systemLanguage which also differentiates between Simplified and Traditional Chinese.
Is that not working for you? Can you please elaborate a bit more in the problem you are seeing? Is it that you are getting a different Region instead of the Simplified variant?
8 years 5 months ago #3053
by enghoff
Replied by enghoff on topic Chinese simplified and traditional dialects
You are completely right, LocalizationManager_SystemLanguage.cs uses the Application.systemLanguage property which does distinguish between Simplified and Traditional Chinese dialects on Android.
I don't believe Application.systemLanguage identifies the device region, but that may be irrelevant for Chinese language settings.
