RTL alignment issue
8 years 5 months ago #3038
by enghoff
RTL alignment issue was created by enghoff
If the term for a Localize component is set programmatically the associated text field does not right-align RTL languages as e.g. Arabic. It is possible the issue applies only if the text field is a TextMeshProUGUI component.
8 years 5 months ago #3048
Replied by Frank on topic RTL alignment issue
Sorry the delay in answering.
I was unable to reproduce that behavior, However, while testing I found a couple corner cases that were misbehaving related to RTL and alignment. This next release is going to focus a lot on RTL improvements, so I will be checking all related to this system.
I will be uploading the first beta with RTL changes early next week or so.
Hope that helps and sorry for this,
8 years 5 months ago #3049
by enghoff
Replied by enghoff on topic RTL alignment issue
Although it does happen completely consistently wherever we set localised terms in code as well as independently on two different titles, it is fairly easy two work around by forcing the correct alignment on the TextMeshProUGUI. Nevertheless it will be helpful to have the issue fixed in the next release, thanks for your always swift and competent response.
