LanguageSource Inspector Assets auto destroy
8 years 4 months ago #3035
by yuewah
LanguageSource Inspector Assets auto destroy was created by yuewah
In v2.8.6 f2, If LanguageSource.Assets is added during runtime, when select the Assets Tab in inspector, the object will auto destroy one by one until empty.
8 years 4 months ago #3036
by yuewah
Replied by yuewah on topic LanguageSource Inspector Assets auto destroy
I find that it is because LanguageSource.Assets is added by loading asset in Resources folder.
However, In LocalizationEditor.cs
GUITools.DrawObjectsArray( mProp_Assets, false, false, false, testAddObj, testReplaceObj, testReplaceIndx, testDeleteIndx);
Since allowResources is false, so it will auto destroy.
8 years 4 months ago - 8 years 4 months ago #3041
Replied by Frank on topic LanguageSource Inspector Assets auto destroy
The problem is that LanguageSource.Assets shouldn't contain any asset from Resources.
The idea of that array is that it includes references to those assets that the plugin can't load at runtime because they are not in the Resources folder.
If you need to add assets (sprites, fonts, etc) from the resources folder, just add the path+name to the translation.
For example:
Term: "MY_FONT", English: "Arial", Spanish:"CustomFonts/Comic"
That will automatically load the Arial font from "Resources/Arial" when in English, and the "Resources/CustomFonts/Comic" when in spanish.
However, if "Arial" is not found in a Resources folder, then the plugin will look for it in the Assets array.
More details here: inter-illusion.com/assets/I2LocalizationManual/AssetsTab.html
For example:
Last edit: 8 years 4 months ago by Frank.
8 years 4 months ago #3042
by yuewah
But I would like to preload all font and material assets during app startup. I tried I2.Loc.ResourceManager, but it doesn't have Addsset( Object Obj ) like LanguageSource
8 years 4 months ago #3043
You can do:
That will load the font if it's not already loaded and save it into the mResourcesCache dictionary so that any time the plugin needs to request that font, it will get it from there.
ResourceManager.pInstance.GetAsset<Font>("Custom Fonts/Comic");That will load the font if it's not already loaded and save it into the mResourcesCache dictionary so that any time the plugin needs to request that font, it will get it from there.
8 years 4 months ago #3045
by yuewah
we need to load all font assets in resources folders, however, there are no method to get all font assets name in the resources folder.
