I2Languages.prefab does not serialize 2.8.6f2
8 years 5 months ago #3034 by LAST CALL
Howdy,
If it hit the T button next to a language when inspecting a term and the language field is updated with the auto-translation the prefab does not re-serialize after the field has changed and I save the project.
So I cannot translate a term and get an updated prefab file using the T button.
To make it work I have to modify the English language field manually and then save again and it re-serializes the prefab file correctly.
Observed on v2.8.6f2 using Unity v2017.1.1p1.
Shawn
8 years 5 months ago #3037 by Frank
Thanks for reporting this, I added a fix to 2.8.7a4
Time to create page: 0.123 seconds
