Having trouble setting language [solved]
8 years 6 months ago - 8 years 6 months ago #3018 by cephalo
Using
LocalizationManager.CurrentLanguageCode = "fr";
does not change the language in my game. Am I supposed to do something else to update scenes with the new language?
Last edit: 8 years 6 months ago by cephalo.
8 years 6 months ago #3020 by Frank
Just to be sure:
- Does your I2Languages.prefab has a language with the code "fr"?
- Is the only language source you are using the I2Languages.prefab or do you have any source instantiated in your scene?
8 years 6 months ago - 8 years 6 months ago #3021 by cephalo
Yes, the language is called 'French' with code 'fr'.
I have six languages, French being one of those, and none of them change the language.
I am using only the one Language Source in the recommended place in I2>Resources. I did recently update I2, but I did not find another one with the new package.
I am running that code in a button, one for each language, and the code is executing as I can print to the debug log inside the button handler that contains the change language code.
    public void OnFrench()
        print("switching to French");
EDIT: It's working now! I believe it wasn't working because I had recently added all the languages. Now that I have shut down the Unity editor and reloaded the project it is working.
8 years 6 months ago #3022 by Frank
weird! haha.
Please, let me know if the problem continue!
Time to create page: 0.154 seconds
