Bug: Multi-Editing Localize Scripts problem
8 years 6 months ago #2985 by Eurban
When multi-editing objects with the "Localize" script, the changes appear to take in the inspector, but they won't function unless I make the change on each individual object, one at a time.
An example would be adding a font to the Secondary tab to multiple object at once. Each object will show to be using that font in the inspector, but nothing will happen. It's as if I made no change at all, even though it displays correctly in the inspector. If re-select the same font, the changes will take.
This also happens with translations. I'm using Text Mesh Pro in all cases, if that makes any difference.
Is there a workaround to this? A way to update all objects to what's set in the inspector?
Fantastic asset by the way! Thanks!
8 years 6 months ago #2988 by Frank
I just uploaded v2.8.6a5 to the beta folder with a fix for this.
