Suggestion: localisation of iOS usage descriptions
8 years 6 months ago - 8 years 6 months ago #2938
by enghoff
Suggestion: localisation of iOS usage descriptions was created by enghoff
I2 Localisation already provides a feature for localising the name of the app, it would be incredibly helpful to have the additional ability to define and localise iOS usage description strings as NSCameraUsageDescription, NSPhotoLibraryUsageDescription, etc.
With thanks,
Sigurd
With thanks,
Sigurd
Last edit: 8 years 6 months ago by enghoff. Reason: typo
8 years 6 months ago #2950
Replied by Frank on topic Suggestion: localisation of iOS usage descriptions
In my todo list for the next releases, I have a task for that,
It has two parts:
1- Localize not only the app name but also "settings" that are common to all stores (e.g. icon, camera, push notification, etc)
2- Allow setting platform custom strings to override texts that are only available in some platform (e.g. android only settings)
The second part will work kind of similar to this:
www.inter-illusion.com/forum/i2-localiza...usagedescription-a-o
In the meantime you could do a similar approach to localize those texts.
It has two parts:
8 years 6 months ago #2954
by enghoff
Replied by enghoff on topic Suggestion: localisation of iOS usage descriptions
Thanks for the link and looking forward to trying out the new feature in the next release of the asset pack.
