First time applying language jumbles translations
- koalitygame
8 years 6 months ago #2929
by koalitygame
First time applying language jumbles translations was created by koalitygame
The first time applying a different language shows the incorrect translations, as if the words are offset from their actual keys. Restarting the app corrects the issue and there are no further errors. Any idea what is causing the initial bug? Below you can see the incorrect translations vs one with no issues.
8 years 6 months ago #2930
Replied by Frank on topic First time applying language jumbles translations
Thanks for reporting this!
I found the issue will upload a fix later today to the beta folder.
The problem is related to Google Live Synchronization not been up-to-date and how the Unload langugages work:
- Whenever the game starts playing, all languages are saved into a temporal file, and removed from memory.
- When you change languages, the correct file is loaded and the previous language is unloaded.
- However, if you Google Spreadsheet has been modified and the Update frequency is set to anything other than NEVER, then the spreadsheet is downloaded
- As soon as the download is finished, the new data is used
The bug is that the downloaded data doesn't update the temporal file until you restart the app. So, if you change languages, the terms could be in a different order.
I'm correcting this in 2.8.6a2. In meantime, you can temporally fix it by disabling Google Live Synchronization: Go to the I2Langauges.prefab, in the Spreadsheet tab, Google, set update frequency to NEVER.
8 years 6 months ago #2931
BTW, another quick fix is to change is to add the SaveLanguages call to
Assets\I2\Localization\Scripts\LanguageSource\LanguageSource_Import_Google.cs
line 338
It should look like this:
line 338
if (UpdateMode == eSpreadsheetUpdateMode.Replace)
UpdateMode = eSpreadsheetUpdateMode.Merge;
// ADD THIS
if (I2Utils.IsPlaying())
SaveLanguages(true);
// UP TO HERE
#if UNITY_EDITOR
if (!string.IsNullOrEmpty(ErrorMsg))
UnityEditor.EditorUtility.SetDirty(this);
#endifHope that helps,
- koalitygame
8 years 6 months ago #2932
by koalitygame
Replied by koalitygame on topic First time applying language jumbles translations
Great, thanks for the response! Does this feature (when working correctly) mean that words in the game can be edited without pushing a new app version to the users?
8 years 6 months ago #2933
Yes, its exactly for that.
Once you link your LanguageSource with an Spreadsheet and set the update frequency to anything other than NEVER (e.g. DAILY, WEEKLY), the game will automatically check if the Spreadsheet was modified, and download the changes.
Then, it will cache those and everytime you run the game it will use the downloaded data. So, no need to push a new build just to change some texts.
See it in action:
More info:
inter-illusion.com/assets/I2Localization...Synchronization.html
See it in action:
More info:
- koalitygame
8 years 6 months ago #2934
by koalitygame
That's amazing, thank you! Keep up the great work on this awesome plugin
