ArgumentException when copying CharSet text
8 years 6 months ago - 8 years 6 months ago #2867 by studenman
I used Google to do a test translation to German and then used the CharSet tool to show the 100 characters that it found.
When I hit "Copy To Clipboard" I get the follow exception, and nothing is copied (screenshot attached):
ArgumentException: invalid utf-16 sequence at -272642832 (missing surrogate tail)
Parameter name: string
I2.Loc.LocalizationEditor.OnGUI_Tools_CharSet () (at Assets/I2/Localization/Scripts/Editor/Localization/LocalizationEditor_Tools_CharSet.cs:109)
I2.Loc.LocalizationEditor.OnGUI_Tools (Boolean reset) (at Assets/I2/Localization/Scripts/Editor/Localization/LocalizationEditor_Tools.cs:42)
I2.Loc.LocalizationEditor.OnGUI_Main () (at Assets/I2/Localization/Scripts/Editor/Localization/LocalizationEditor.cs:80)
I2.Loc.LocalizationEditor.OnInspectorGUI () (at Assets/I2/Localization/Scripts/Editor/Inspectors/LanguageSourceInspector.cs:163)
However, if I cursor around in the text, I noticed that there are about 10 invisible characters at the end of this text. If I manually copy the visible characters with Cmd+C, then I don't get an exception.
Twitter | Facebook | Web
Last edit: 8 years 6 months ago by studenman.
8 years 6 months ago #2870 by Frank
I have been trying to reproduce this issue but I haven't been able to make it happen.
Do you mind emailing me your I2Languages.prefab or a csv that include the german texts you are using. I will add a fix as soon as I be able of reproducing the crash.
Thanks!!
8 years 6 months ago - 8 years 6 months ago #2873 by studenman
OK, I don't know your email, so I sent it to admin @ i-i . com
The prefab has en-US, de-DE, and ja in there. Same thing happens with CharSet and japanese. There are invisible characters in the resulting text and they cause an exception on copy.
8 years 6 months ago #2882 by Frank
This is now fixed in 2.8.5a2.
The problem was that some character combinations where making unity believe that the resulting string had UTF-16 encoding, (and unity doesn't support that encoding correctly).
Now all its forced to be UTF-8.
8 years 6 months ago #2883 by studenman
Excellent, glad you were able to reproduce it!
