Objects not localizing in Unity 2018.1 beta
8 years 7 months ago #2827
Objects not localizing in Unity 2018.1 beta was created by Frank
It seems that in the 2018.1 beta, the behavior of the [RuntimeInitializeOnLoadMethod] and [InitializeOnLoad] attributes changed and now it can't be inherited.
I will be releasing a new beta later tomorrow (2.8.4a6) with the a complete fix, but in the meantime, a way to fix it locally is to open each of the targets in the folder Assets\I2\Localization\Scripts\Targets
and change thewith:
and thewith
it should look like this:
and change the
[I2EditorInitialize] #if UNITY_EDITOR
[UnityEditor.InitializeOnLoad]
#endif and the
[I2RuntimeInitialize][RuntimeInitializeOnLoadMethod(RuntimeInitializeLoadType.BeforeSceneLoad)]it should look like this:
namespace I2.Loc
#if UNITY_EDITOR
#endif
public class LocalizeTarget_UnityUI_Text : LocalizeTarget<UnityEngine.UI.Text>
static LocalizeTarget_UnityUI_Text() { AutoRegister(); }
[RuntimeInitializeOnLoadMethod(RuntimeInitializeLoadType.BeforeSceneLoad)] static void AutoRegister() { LocalizationManager.RegisterTarget(new LocalizeTargetDesc_Type<Text, LocalizeTarget_UnityUI_Text>() { Name = "Text", Priority = 100 }); }
8 years 7 months ago #2858
by Dakk
Replied by Dakk on topic Objects not localizing in Unity 2018.1 beta
I am seeing this same issue in the new LTS Unity build- 2017.4.0f1.
I have I2L v 2.8.4f1 but it does not seem to fix the problem.
Some seemingly random text does not translate- some does. Some text shows the Key value instead of a translation.
Any help appreciated.
Time to create page: 0.123 seconds
