I have a some question. please help me
8 years 8 months ago - 8 years 8 months ago #2795 by Youngs
Please excuse the fact that English is not natural with the help of translator.
We are using the " I2 Localization " and have recently been updated to version 2.8.3 F1.
After the update, however, a warning displayed this message.
"No script asset_LocalizeTarget_TextMeshPro_ADDC.check that is the definition is in the file of the name"
Can I know the solution?
Last edit: 8 years 8 months ago by Youngs.
8 years 8 months ago #2798 by Frank
When updating, did you deleted the old installation before installing the new one?
It could be that there are some old files left over.
Try deleting the I2 folder and installing the plugin again.
Also, LocalizeTarget_TextMeshPro is used only if you have TextMesh Pro installed in your project and the TextMeshPro label is set in the Script Define Symbols.
Please, check that's correctly set up:
inter-illusion.com/assets/I2Localization...lizationTargets.html
The following user(s) said Thank You: Youngs
8 years 8 months ago #2806 by Youngs
The problem has been corrected. thank you very much!!! :cheer:
Time to create page: 0.183 seconds
