Index misscalculation issue
- bahattintancoskuner
- Thank you received: 1
8 years 9 months ago #2755
by bahattintancoskuner
Index misscalculation issue was created by bahattintancoskuner
I have noticed an index misscalculation bug that prevents me to use multiple local parameters.
In LocalizationManager_Parameters.cs :
Change to this instead :
Please consider this bug in your new versions.
Have a good day.
private static void ApplyLocalizationParamsInternal(ref string translation, _GetParam getParam)
if (translation == null)
return;
string pluralType=null;
int idx0 = 0;
int idx1 = translation.Length;
int index = 0;
while (index>=0 && index<translation.Length)
int iParamStart = translation.IndexOf("{[", index);
if (iParamStart < 0) break;
int iParamEnd = translation.IndexOf("]}", iParamStart);
if (iParamEnd < 0) break;
// there is a sub param, so, skip this one: "this {[helo{[hi]} end"
int isubParam = translation.IndexOf("{[", iParamStart+1);
if (isubParam>0 && isubParam<iParamEnd)
index = isubParam;
continue;
var param = translation.Substring(iParamStart + 2, iParamEnd - iParamStart - 2);
var result = (string)getParam(param);
if (result != null)
var paramTag = translation.Substring(iParamStart, iParamEnd - iParamStart + 2);
translation = translation.Replace(paramTag, result);
int amount = 0;
if (int.TryParse(result, out amount))
pluralType = GoogleLanguages.GetPluralType(CurrentLanguageCode, amount).ToString();
index = iParamEnd + 2; //<== HERE : when the first parameter replaced, the size of thw word changed too so it should be recalculated
}Change to this instead :
return;
int idx0 = 0;
int index = 0;
index = isubParam;
continue;
if (result != null)
int amount = 0;
index = iParamEnd - (param.Length - result.Length) - 2; //TODO: This calculation is fixed, index calculation was wrong after replacing
else //TODO: wrapped with else
}Please consider this bug in your new versions.
Have a good day.
The following user(s) said Thank You: Frank
8 years 9 months ago #2758
Replied by Frank on topic Index misscalculation issue
Thanks for looking into that.
I verified the issue and added the fix.
I also created a Unity Test to verify all possible Parameters and tag combinations, so that this error doesn't repeat in any future update.
Again, Thanks a lot for the suggestion!
Time to create page: 0.125 seconds
