Problem of RTL language with Android Native
8 years 9 months ago #2733
by wangzy_88
Problem of RTL language with Android Native was created by wangzy_88
I found that when I wanted to display a word (RTL language) from I2 by Toast of Android, the order of the characters would be reversed, and the word would have no problem if it did not from I2.
Hope to have a solution, thank you for advance.
8 years 9 months ago - 8 years 9 months ago #2734
Replied by Frank on topic Problem of RTL language with Android Native
Can you send me an screenshot of that issue and the text you are using. That will help me reproduce the error, because I'm not seeing it happen in my local builds.
Also, does it work in the Editor and not in the Device, or doesn't work in either?
What version of I2 Localization are you using?
Last edit: 8 years 9 months ago by Frank.
8 years 9 months ago - 8 years 9 months ago #2735
by wangzy_88
Replied by wangzy_88 on topic Problem of RTL language with Android Native
Thank you for very quick reply. The sentence I used to test is: "اضغط مرة أخرى للخروج". And the attachment is my test scene with I2 v2.8.1.
Last edit: 8 years 9 months ago by wangzy_88.
Time to create page: 0.126 seconds
