Problem Arabic Language
12 years 2 months ago #232 by titanire
When i put an arabic character in Language source/ Terms, the word is reverse and if i launch the game, it's exactly the same.
it's not the correct direction.
(I use last version of Ngui and last version of I2 localization)
Also, Do you have any suggestion for me or a solution.
Thanks a lot for any reply !
12 years 2 months ago - 12 years 2 months ago #233 by Frank
Replied by Frank on topic Problem Arabic Language
I just double checked the Arabic rendering, and in the last version, it was accidentally disabled because the language code was not being set when changing the language.
I correct that and made an example scene showing how to setup the correct Right To Left text rendering.
I will be releasing the new version over the weekend along with a few more fixes and improvements.
Nonetheless, I'm attaching the LocalizationManager.cs that fixes the issue.
Thanks for catching that bug!!
Attachment LocalizationManager.zip not found
Last edit: 12 years 2 months ago by Frank.
12 years 2 months ago #234 by titanire
Replied by titanire on topic Problem Arabic Language
Hi !
Thanks you for the reply, but i have an error when i change this file :
Assets/I2/Localization/Scripts/LocalizationManager.cs(139,72): error CS0308: The non-generic method `I2.Loc.ResourceManager.GetAsset(string)' cannot be used with the type arguments
Thank for reply ! :)
Titanire
12 years 2 months ago #235 by Frank
Ahhh, that file seems to depend on the new functions in the ResourceManager. There has been quite a few changes for the features.
You will have to update to the new version to get all the changes. I will try packing an early beta tomorrow that you could download.
Sorry for the issue and thanks for detecting it. Please, if you find any other thing or have any suggestion, let me know! I'm trying to include as many fixes as possible in the next release.
12 years 2 months ago #236 by Frank
Nonetheless, a quick workaround for that compile error is to replace
GameObject Prefab = (ResourceManager.pInstance.GetAsset<GameObject>("I2Languages"));
by
GameObject Prefab = (ResourceManager.pInstance.GetAsset("I2Languages")) as GameObject;
The following user(s) said Thank You: titanire
12 years 2 months ago #237 by titanire
Awesome it's work !
Thanks you very Much and Keep rocking !
Titanire
Time to create page: 0.234 seconds
