I'm new - Have a few issues
10 years 3 months ago #1620 by dip_registered
I'm new to this plugin. It seems brilliant but I can't seem to get a few things working.
For one, I can't use the google 'translate' option - When I click translate next to the language term for all of my languages, an error messages pops up saying "WebsService is not set correctly or needs to be reinstalled". I tried re-installing the plugin, as well as re-importing all assets into the project, it did not fix it.
Also, I have set up buttons to change the languages, but they are not working either. a) I set up a text object with Localization script, have a term created and selected, and input test text for all languages. b) I create a button, and apply the SetLanguage Script, choosing the language and inserting i2Languages prefab into the Language Source. For some reason its not working... Can anyone see what I'm doing wrong?
Many thanks,
Ben
10 years 3 months ago #1622 by dip_registered
Ok, got the translator working... Hadn't set up my Google drive yet... Lets see if this fixes my other issue...
10 years 3 months ago #1623 by dip_registered
Still having trouble getting my buttons to set languages...
I've added theDf Set Language (Script) instead, and typed the language in, but it is not changing my text.
Thanks for your help,
Ben
10 years 3 months ago #1625 by jimmyt3d
You need tell the On Click() what to do...
- Add the languages in the Languages tab in the prefab
- Make a button and add the 'Set Language' script to it
- Choose the language you want assigned to the button (on the dropdown in the Inspector), then drag the language source prefab to the 'Language Source' box
- Then in the On Click() box for the button, choose the button itself and choose SetLanguage > Apply language
It should look like the screenshot attached.
The following user(s) said Thank You: dip_registered
10 years 3 months ago #1627 by dip_registered
Fixed the issue, thank you! I'm a bit of a noob at unity so this helped a lot.
