45 minute import?
- OrenMunkyFun
10 years 7 months ago #1321
by OrenMunkyFun
Replied by OrenMunkyFun on topic 45 minute import?
OK! Much appreciated.
10 years 7 months ago - 10 years 7 months ago #1322
Replied by Frank on topic 45 minute import?
I finished updating the I2Location to be compatible with the WebService changes.
The new beta (2.6.5b1) can be downloaded from the beta folder.
I tested with a big spreadsheet (15 sheets, each sheet with 1000-7000 terms) and it imported it in 5 seconds (previously was quite a few minutes)
Hope that helps!
*Exporting the spreadsheet still takes quite some time, will optimize that next
Hope that helps!
Last edit: 10 years 7 months ago by Frank.
10 years 7 months ago #1323
Just changed the code a bit more to make it way faster when viewing large databases.
Previously, when the LanguageSource had a few thousand terms, moving through the terms list was very slow, now is way smoother.
These changes are in 2.6.5b2 which can be downloaded from the beta folder.
10 years 7 months ago #1324
I changed the code to speedup uploading the spreadsheet to google.
It is far far faster, although, on huge spreadsheets, it still takes a bit longer than what I would like. I will keep working on improving that up.
The new changes can be found in the beta folder I2L v2.6.5 b3. Notice that this new beta requires reinstalling the webservice in your google drive!
Hope that helps!
Hope that helps!
Time to create page: 0.186 seconds
