CSV Import Problem
10 years 11 months ago #1052 by Frank
Replied by Frank on topic CSV Import Problem
I have been retesting a lot, and no matter what I can't reproduce your issue. I created an empty project, downloaded the latest I2 Loc, and created an script with the code you posted.
using UnityEngine;
using System.Collections;
using System.IO;
using I2.Loc;
public class test : MonoBehaviour
	void Start ()
		string CSVstring;
		CSVstring = File.ReadAllText(Application.streamingAssetsPath + "/fr.csv");
		LocalizationManager.CurrentLanguage = LocalizationManager.CurrentLanguage;
		LocalizationManager.Sources[0].Import_CSV(string.Empty, CSVstring, eSpreadsheetUpdateMode.Replace, ';');
It loaded the fr.csv without adding any \r at the end.
Can you please try that and load the fr.csv you posted here.
I'm thinking that it may have something to do with some other assets or scripts in your project. Or that the fr.csv file doesn't have the same issue than the one you are using.
BTW, I tested on unity 4.6 and 5.2. Both on Windows. Haven't been able to test on Mac yet.
Are you using windows or mac?
Sorry for this issue, and as soon as I get able to reproduce it I will include in all future updates.
PS. BTW, a safer and better way to load the CSV from the file, its by using
var CSVstring = LocalizationReader.ReadCSVfile( filename );
That function replaces any \r\n and \r by \n and also works correctly in Metro and W8P.
Nonetheless, even with the code you sent me I'm not able to reproduce the \r issue.
10 years 8 months ago - 10 years 8 months ago #1232 by wagenheimer
Replied by wagenheimer on topic CSV Import Problem
This worked for me! Now it works as expected!
Thanks! =)
Last edit: 10 years 8 months ago by wagenheimer.
Time to create page: 0.175 seconds
