SetTerm won't update
11 years 3 months ago #916
by Stiv
Replied by Stiv on topic SetTerm won't update
Thanks for looking into it. I've since discovered a number of other places it's not working so I don't think my problem is just on prefabs now. I should have also mentioned I'm using TextMesh Pro for all my text.
I just tried creating a new blank project and everything works ok there so I guess I'm a bit stuck.
One really weird thing I just noticed is that if I press the translate button in my main project, it puts the key name / category as the translation instead of an actual translation. Never seen that before and it doesn't happen in the test project.
If I can work out how to replicate the SetTerm issue outside of my project I'll let you know. If not I guess I'll roll back to the last working version (the version on the asset store).
Thanks again.
Thanks again.
11 years 3 months ago #917
Replied by Frank on topic SetTerm won't update
Just to double check:
Are you using the I2Languages.prefab for your localizations?
Do you have any other LanguageSource instantiated in your scene?
11 years 3 months ago #918
by Stiv
Yes just the I2Languages.prefab in Assets>I2>Localization>Resources, no other language sources.
11 years 2 months ago #938
by Stiv
Just a final update to close this one off, I was able to solve my problem by making the following change to OnLocalize:
Somehow my calls to "SetTerm" where getting lost, possibly because they were set when not active and later when it was activated "OnEnable" didn't update it because the "CurrentLanguage" hadn't changed. Not totally sure, but this is working for me now so I'm happy
(Oh, and this is 2.6.0 b6)
public void OnLocalize( bool Force = false )
if (!Force && (!enabled || !gameObject.activeInHierarchy))
return;(Oh, and this is 2.6.0 b6)
11 years 2 months ago #940
Thanks for finding this workaround. I will check why it could have been failing and include the fix in the next beta!
Thanks!!
Thanks!!
11 years 2 months ago #943
by Stiv
Hi frank, I think my suspicions where correct. This is how I've been able to reproduce it in a blank project:
Have a localized label visible on scene load (I'm using TextMesh Pro in case it makes a difference). Later set it inactive. Call SetTerm while inactive. Enable the label again later and it will still be the original term.
This was my very simple test case:
public Localize label;
public float counter = 0f;
void Update ()
if (counter < 1f && counter + Time.deltaTime >= 1f)
// Set inactive
label.gameObject.SetActive(false);
else if (counter < 2f && counter + Time.deltaTime >= 2f)
// Change term
label.SetTerm("Label/Test2");
else if (counter < 3f && counter + Time.deltaTime >= 3f)
// Set active again
label.gameObject.SetActive(true);
counter += Time.deltaTime;
}Please Log in or Create an account to join the conversation.
