Editor error in 2.4.4.f1
11 years 6 months ago #552
by Stiv
Editor error in 2.4.4.f1 was created by Stiv
Hi!
Today I updated to the latest version of I2 Localization (2.4.4 f1) and I'm now getting an error in the unity editor.
Have you seen this before?
I'm running Unity 5.0.0.f4 (64-bit) and as far as I can tell this error isn't stopping anything working in-game.
Any help would be appreciated!
Cheers
System.Security.VerificationException: Error verifying I2.Loc.UpgradeManager:.cctor (): This object not compatible with function pointer for delegate creation at 0x0020
UnityEditor.EditorAssemblies:SetLoadedEditorAssemblies(Assembly[])I'm running Unity 5.0.0.f4 (64-bit) and as far as I can tell this error isn't stopping anything working in-game.
Cheers
11 years 6 months ago #553
Replied by Frank on topic Editor error in 2.4.4.f1
The plugin now every few days checks the assetstore to see if there is a new version of the plugin so you be always up to date.
That error means that the check is failing.
Is your Editor set to WebPlayer?
I will test this new feature in different platforms and try reproducing that issue. Will give you update asap.
11 years 6 months ago #554
I double checked and the issue was that the update delegate had an optional parameter. Even when its optional, the latest versions of unity doesn't allow it.
That will be fixed in the new version of the plugin and doesn't affect the functionality.
You can easily fix the issue in your local project to avoid having that error shown everytime you open unity.
Just replace this section from the I2\Localization\Scripts\Editor\UpgradeManager.cs
by this one
static UpgradeManager()
I2.I2AboutWindow.PluginsVersion["I2 Localization"] = LocalizationManager.GetVersion();
EditorApplication.update += CheckPlugins;
public static void CheckPlugins( bool bForce = false )
EditorApplication.update -= CheckPlugins;
EnablePlugins(bForce);
CreateLanguageSources();
CreateScriptLocalization();
}by this one
EditorApplication.update += AutoCheckPlugins;
public static void AutoCheckPlugins()
CheckPlugins ();
EditorApplication.update -= AutoCheckPlugins;
}Thanks,
11 years 6 months ago #555
by Stiv
Replied by Stiv on topic Editor error in 2.4.4.f1
Yes my editor was set to Web Player. I've just tried the suggested change and the error is gone
Thanks for the awesome support as always!
Cheers,
Steve
Cheers,
Steve
11 years 6 months ago #556
by Stiv
Oh, and one other minor thing. When I look at the About page for I2 Localization in the Unity Editor it says that the latest version in the asset store is 2.4.4.f2 but as far as I can tell the asset store is still on f1. Is that right?
11 years 6 months ago #557
Given that you have the Editor set to WebPlayer, the plugin manager is not able to contact the store to retrieve the correct version. In that case, the values you are seeing are the one that I set as default in the editor script.
As soon as you switch your project into any other platform, the plugin will be able of downloading the latest info and will keep a copy just in case it looses contact later on
I will see if I can add the crossdomain xml to fix this issue with the web player!
Thanks for testing this!!!
Time to create page: 0.137 seconds
