Localizing Dropdown values font
4 years 9 months ago - 4 years 9 months ago #4874 by Kaizen
can you tell me the way to localize TMP dropdown values font?
I do use a LocalizeDropdown but I don't see any option like in the i2 localize component (secondary tab).
EDIT: nevermind I found the solution, I added the I2 localize component on the labels and just filled the secondary tab.
I still have this concern:
Other related question: I have a language list filled with language names in their respective language, I use a localized term called language_list and fill the dropdown dynamically with this term's values.
it's working well but how do I have a specific font for that Chinese value?
Thanks for your help in advance!
EDIT: I did found a way but I'm not sure it's the best way.
I used Rich text provided by tmp pro
The font asset should be placed in the correct path defined in the TMP Settings or it won't work: digitalnativestudios.com/textmeshpro/docs/settings/#font
Last edit: 4 years 9 months ago by Kaizen.
Time to create page: 0.178 seconds
