Select Language Term by Term
- chillerVille
10 years 8 months ago #1211
by chillerVille
Replied by chillerVille on topic Select Language Term by Term
If all it takes to change the font is to make this assignment:
Localize.SecondaryTranslation = fontName;
... I don't find a way to get that fontName for the chosen language.
10 years 8 months ago - 10 years 8 months ago #1212
Replied by Frank on topic Select Language Term by Term
Just need to get the termData for the secondary term as well and set that:
That should be work.
Also, in one of the latest versions, the CallBackTerm and CallBackSecondaryTerm was introduced to avoid having to call GetFinalTerms.
So, a simpler way its:
public void OnModifyLocalization() {
string language = m_sceneManager.GetSystemLanguage();
string term, secondary;
GetComponent<I2.Loc.Localize>().GetFinalTerms(out term, out secondary);
var termData = LocalizationManager.GetTermData(term);
var secTermData = LocalizationManager.GetTermData(secondary); // added
int languageIndex = LocalizationManager.Sources[0].GetLanguageIndex(language);
if (languageIndex >= 0) {
if (termData != null)
Localize.MainTranslation = termData.Languages[languageIndex];
if (secTermData != null) // added
Localize.SecondaryTranslation = secTermData.Languages[languageIndex]; // added
}That should be work.
if (languageIndex < 0)
return;
//--[ Text ]--------------
var termData = LocalizationManager.GetTermData(Localize.CallBackTerm);
//--[ Font ]--------------
var secTermData = LocalizationManager.GetTermData(Localize.CallBackSecondaryTerm );
}Hope that helps,
Last edit: 10 years 8 months ago by Frank.
- chillerVille
10 years 8 months ago #1213
by chillerVille
Thanks Frank, you just made my day, and fixed the one and only problem we had with I2 Localization system.
I've seen what they use at Ubisoft, and a couple of other companies, but your localization system work just much better.
100%!
Frank wrote: Hi,
public void OnModifyLocalization() { string language = m_sceneManager.GetSystemLanguage(); string term, secondary; GetComponent<I2.Loc.Localize>().GetFinalTerms(out term, out secondary); var termData = LocalizationManager.GetTermData(term); var secTermData = LocalizationManager.GetTermData(secondary); // added int languageIndex = LocalizationManager.Sources[0].GetLanguageIndex(language); if (languageIndex >= 0) { if (termData != null) Localize.MainTranslation = termData.Languages[languageIndex]; if (secTermData != null) // added Localize.SecondaryTranslation = secTermData.Languages[languageIndex]; // added } }
public void OnModifyLocalization() { string language = m_sceneManager.GetSystemLanguage(); int languageIndex = LocalizationManager.Sources[0].GetLanguageIndex(language); if (languageIndex < 0) return; //--[ Text ]-------------- var termData = LocalizationManager.GetTermData(Localize.CallBackTerm); if (termData != null) Localize.MainTranslation = termData.Languages[languageIndex]; //--[ Font ]-------------- var secTermData = LocalizationManager.GetTermData(Localize.CallBackSecondaryTerm ); if (secTermData != null) Localize.SecondaryTranslation = secTermData.Languages[languageIndex]; }
10 years 8 months ago #1214
I'm glad it's working for you now!!!
Some big companies like SGN have been using it, but the more the merrier!
It will definitely be great if they start using I2L hahaI've seen what they use at Ubisoft, and a couple of other companies, but your localization system work just much better.
