Dynamic text
5 years 3 months ago #4388
by JmPrsh
Dynamic text was created by JmPrsh
So i spanw in a text gameobject which changes its whole line depending on the language. Any idea how i can dynamically control this? controlling static text is easy but text that i change seems a pain
5 years 3 months ago #4389
Replied by Frank on topic Dynamic text
Instead of changing the text, change the term.
so, instead of doing:
go.text = "Level Completed";
go.text = "Level Failed";
you should create a term for each text you want to set (so that they could be translated).
and then do:
go.GetComponent<I2Localize>().SetTerm("Level Completed");
go.GetComponent<I2Localize>().SetTerm("Level Failed");
The SetTerm will find the translation of the "Level Completed" to the current language and set the .text with that translation.
and then do:
5 years 2 months ago #4391
by JmPrsh
Replied by JmPrsh on topic Dynamic text
So i found out how to do it in a specific way before i reply to your comment. I basically use this ... go.text = LocalizationManager.GetTranslation("Level complete"); and then fail... although looking through the code it looks like it would have to go through a foreach loop each time so maybe your suggesting would be better instead
5 years 2 months ago #4392
by JmPrsh
Also i use the get component etc but I2Localize cannot be found for some reason
