BUG - Arabic Text - Max Line Length Breaks Rich Text Tags
5 years 4 months ago #4333
by nindim
BUG - Arabic Text - Max Line Length Breaks Rich Text Tags was created by nindim
NOTE: I turned off Adjust Alignment for these test as the rich text tags break in other ways with that enabled:
inter-illusion.com/forum/i2-localization...reaks-rich-text-tags
When using the "Max Line Length "option it can add line breaks which break rich text tags.
Example string:
<b>ضاعف XP</b>
من خلال مشاهدة شريط فيديو قصير
Broken Result with Max Line Length: 10
Expected Result with Max Line Length: 11
I would expect only visible characters to be taken into consideration for the Max Line Length and for formtting to remain intact.
Thank you!
Example string:
<b>ضاعف XP</b>
Thank you!
5 years 3 months ago #4352
by flors
Replied by flors on topic BUG - Arabic Text - Max Line Length Breaks Rich Text Tags
Hi!
I'm working with arabic and I can't have it working using spreadsheets any advice for implementing arabic translation??
I'll appreciate your help!
