Bug: I2Utils FindNextTag doesn't handle Nested Tags causing
5 years 9 months ago #4192
by UltraRat
If ApplyRTLfix has a string with multiple types of tag starters like <!-Missing [TermName]-!> an IndexOutOfRangeException is fired because FindNextTag marks < as the tag start and ] as the tag end which can't restore the tags correctly.
I've worked around it for now, just reporting it since I didn't see it anywhere.
5 years 3 months ago - 5 years 3 months ago #4330
by nindim
Replied by nindim on topic Bug: I2Utils FindNextTag doesn't handle Nested Tags causing
I think we are hitting the same error when switching to Arabic. The cause seems to be having a missing string in the game.
It would be great to get this fixed as it's firing a lot during development.
Thank you!
Software Versions
Unity 2018.4.23
Text Mesh Pro: 1.5.0 Preview 11
I2 Localization: 2.8.13 f2
IndexOutOfRangeException: Index was outside the bounds of the array.
at I2.Loc.LocalizationManager.ApplyRTLfix (System.String line, System.Int32 maxCharacters, System.Boolean ignoreNumbers) [0x00132] in XXX\Assets\I2\Localization\Scripts\Manager\LocalizationManager_RTL.cs:60
at I2.Loc.Localize.OnLocalize (System.Boolean Force) [0x003ad] in XXX\Assets\I2\Localization\Scripts\Localize.cs:224
at I2.Loc.Localize.OnEnable () [0x00001] in XXX\Assets\I2\Localization\Scripts\Localize.cs:145 It would be great to get this fixed as it's firing a lot during development.
Thank you!
Software Versions
Unity 2018.4.23
Last edit: 5 years 3 months ago by nindim.
Time to create page: 0.137 seconds
