Changing languages order doesn't trigger I2Languages.asset update
6 years 4 months ago #4121
by Vlad-M-1
It seems that there's a problem with changing languages order. The changes are applied during the current session with Unity. But are not saved if nothing else is changed.
I use "First in List" as a default language, so it causes an undesired behavior.
I found, though, that if I change some term, I2Languages.asset gets updated, and it works fine. So the solution seems to be adding I2Languages.asset update on languages order change.
Time to create page: 0.163 seconds
