Problem using API with plural translations
- cygnusprojects
6 years 11 months ago #4012
by cygnusprojects
Problem using API with plural translations was created by cygnusprojects
Hi there,
I found the following code on this forum to translate my plural term through API calls:and thisI applied this to my code like this:or even this:but all do end in the same error message:Looking at the code using that stacktrace this seems to be the issue:
Any tip/hints on how to get this working?
I'm on Unity 2019.2.13 and I2 localization 2.8.13 f2 according to the readme.
var dict = new Dictionary<string, int>();
dict["MATCHES_LEFT"] = 5;
string translation = LocalizationManager.GetTranslation( "TERM_FIGHTS" )
LocalizationManager.ApplyParameters(ref translation, dict);string translation = LocalizationManager.GetTranslation( "TERM_FIGHTS" )
LocalizationManager.ApplyParameters(ref translation, (p)=>{ return p=="MATCHES_LEFT" ? 5 : null; });string translation = LocalizationManager.GetTranslation(".STARS. needed to unlock");
LocalizationManager.ApplyLocalizationParams(ref translation, (p) => { return p == "NR" ? 5 : 0; });var dict = new Dictionary<string, object>();
dict["NR"] = Contract.StarsNeed2Unlock;
LocalizationManager.ApplyLocalizationParams(ref translation, parameters:dict);InvalidCastException: Specified cast is not valid.
I2.Loc.LocalizationManager.ApplyLocalizationParams (System.String& translation, I2.Loc.LocalizationManager+_GetParam getParam, System.Boolean allowLocalizedParameters) (at Assets/I2/Localization/Scripts/Manager/LocalizationManager_Parameters.cs:84)
I2.Loc.LocalizationManager.ApplyLocalizationParams (System.String& translation, System.Collections.Generic.Dictionary`2[TKey,TValue] parameters, System.Boolean allowLocalizedParameters) (at Assets/I2/Localization/Scripts/Manager/LocalizationManager_Parameters.cs:46)
ContractUI.OnLocalize () (at Assets/Scripts/UI/ContractUI.cs:67)var result = (string)getParam(param); where param has the value NRAny tip/hints on how to get this working?
Time to create page: 0.108 seconds
