Canada english french problem
- madaboutpandas
Topic Author
- Thank you received: 1
7 years 3 weeks ago #3983
by madaboutpandas
Canada english french problem was created by madaboutpandas
When I create in the inspector Language Source the language French->Canada it is listed as fr-CA. There is no English->Canada.
I have setup the Google Doc synchronisation, which works well in general. Now I do Spreadsheet Import Replace, this copies the google doc into the local database. The column labeled with "Canada" in the doc changed now from fr-CA into en-CA in the inspector. Why? The language should stay french,
Please help.
Kind Regards,
Chris
Please help.
Kind Regards,
Chris
- madaboutpandas
Topic Author
7 years 6 days ago #3990
by madaboutpandas
Replied by madaboutpandas on topic Canada english french problem
Someone?
- madaboutpandas
Topic Author
7 years 5 days ago #3992
by madaboutpandas
I finally found the problem and the solution is quite simple: Change the header in the Google Doc sheet from "Canada" to "French Canada".
Time to create page: 0.120 seconds
