Google Sync Does not work at all
11 years 11 months ago #312
Replied by Frank on topic Google Sync Does not work at all
Don't worry, I'm not offended or anything!
I tested your code and indeed that was am issue with the latest version. Thanks for catching that up.
In previous version, the I2Languages.prefab was always loaded by default. So, when the call to GetTermTranslation was done, it query for the CurrentLanguage and as there was not one set, it initialized the plugin. But now the I2Languages is not loaded by default if you are not using a Localize component.
So, if you want to use everything from scripts, you need to init the plugin.
I added a condition now to the GetTermTranslation so that if the language is not defined when that function is called, it will start the initialization.
Thanks for catching that issue!!
Please, let me know anything else you can find!
11 years 11 months ago #313
by Stehlik
Replied by Stehlik on topic Google Sync Does not work at all
So another quick test
when I call first
LocalizationManager.CurrentLanguageCode
it does not load anything
I still have to call this to load resources
and after that I can obtain my Language Code..
That makes me a sad panda
when I call first
11 years 11 months ago #314
I just added the InitializeIfNeeded to that as well.
11 years 11 months ago #315
by Stehlik
Ok so the CurrentLanguageCode is not working in my favour
I mostly work with codes because they are more standardized then the name of the language...
set CurrentLanguageCode does actually nothing.
public static string CurrentLanguageCode
get { return mLanguageCode; }
set {
mLanguageCode = value;
IsRight2Left = IsRTL (mLanguageCode);
it does not change the language at all
also it does not write the language settings on disk.
I would recommend to highly unit test your code, as there are abviously methods which do nothing usefull
and can be missleading :-/
set {
11 years 11 months ago #316
by Stehlik
Also I need to convert between Language name and Language code and I can't see any function which will do that
11 years 11 months ago #317
by Stehlik
Oh I see
GetLanguageCode
but is there also GetLanguageFromCode ?
GetLanguageCode
