How to parse text from script?
8 years 3 months ago #3164
by JOY
How to parse text from script? was created by JOY
Hi. How to parse text from scripts? I tried to look for it in tools but cannot find.
8 years 2 months ago #3213
by pete
Replied by pete on topic How to parse text from script?
I have the same issue, I'd like to be able to add a string value to the I2Languages without adding the terms manually.
Is it something possible?
Or the only way to call a string from a script is using this:
www.inter-illusion.com/assets/I2Localiza...riptsforsaferac.html
8 years 2 months ago #3214
by pete
Ok I found a way
