Resources.Load stops working after I2 Localization
8 years 4 months ago #3110
So, yes, destroying that it very bad haha.
That error its weird. Does the prefab you try to instantiate with Resources.Load has any Localize component attached? Does it have a LanguageSource?
Can you place a Debug.Log to verify that the prefab is not actually null?
The plugin doesnt load any csv file, all the localization is stored in the I2Languages.prefab.
Are you manually loading the csv file to then call Import_CSV?
The thing about the having the Debug.Log(I2.Loc.LocalizationManager.CurrentLanguage) affecting things, is that whenever you set or query the currentLanguage, if the localization is not initialized, then it tries to initialize it (loads the language sources and updates the internal dictionary).
A few things to look out:
Did you move/deleted the I2Languages.prefab?
Are you instantiating any LanguageSource in your scene?
Are all your asset references valid? (I mean the objects referenced in the Assets tab in the I2Languages.prefab and the Localize component References section)
inter-illusion.com/assets/I2LocalizationManual/AssetsTab.html
Are you localizing any Font? If so, does the term points to a valid path in the Resources folder?
Replied by Frank on topic Resources.Load stops working after I2 Localization
The plugin uses a coroutine to delay localization to the end of the frame (instead of doing a full localize everytime a term changes) and to download data from google. To manage those coroutines it creates a hidden manager set to Dontdestroyonload to keep downloading data even when switching scenes.I was detecting and destroying all "DontdestroyOnLoad" objects
error: The object you are trying to instantiate is null
Error Access to the path "/storage/emulated/0/tracesPending.csv" is denied.
8 years 4 months ago #3111
by Oakshiro
Replied by Oakshiro on topic Resources.Load stops working after I2 Localization
Hello.
Fist of all, thanks for helping me so much.
The I2Languages.prefab was inside I2/Localization/Resources. The system itself asked me to move it to I2/Resources , and that's where it is right now.
I am not instantiating any LanguageSource
And, i have no Assets other than the text, so that tab is empty.
I will keep on searching, could it be because any other android plugin is interfering? In the Editor everything is ok. Is just the Android build that is not being Localized.
8 years 4 months ago #3112
by Oakshiro
Hello!
I finally achieved to make it work.
I simply removed everything and did a fresh install of v2.8.6 and now works like a charm.
I don't know why it didn't work, but I'll perfectly live without knowing it
Time to create page: 0.124 seconds
