'Set Language' script seems to override Callbacks
8 years 5 months ago #3089 by EdSludden
I have a button in my main menu which uses the 'Set Language' script, and whenever its pressed, the text components on other gameobjects are always translated. This is desired behavior.
However, if I use a Callback function within the Text Components 'Localize' script, I can't modify the text to ignore the translation when the Set Language script is used.
e.g. If a user inputs their name in a text box, I used the callback function to get the script to ignore the translation. But the Set Language script always resets the Text component to its default value, and then displays it.
I can't seem to update this text component at runtime or in editor. Am I using the Callbacks properly?
Thankyou.
8 years 5 months ago #3090 by EdSludden
I think I can get around this by disabling the Localize component by default, and enabling it(or not) after the Set Language script is used.
8 years 5 months ago #3091 by EdSludden
Yes, it worked. This thread can probably be closed.
Many thanks!
Time to create page: 0.125 seconds
