WebService Security
8 years 5 months ago #3069
Replied by Frank on topic WebService Security
I'm not very sure this is actually a bug, it can be either way.
The point is, that if you requested the spreadsheet list, and you were able to get it (because of your WebService had no password), then after you set a password, even if they don't match, there is no point in deleting the list. You already accessed and saw that information!
Said that, if you changed your webService URL, then it makes sense to clear that list because it may be referencing to a different google drive. So, it will show old/invalid names.
Either way, just to be sure, I will clear the list everytime you click the "Refresh" button, that way if it fails and shows "Wrong Password", you get even more confirmation that failed when you see the list empty.
8 years 5 months ago #3070
by bibz87
Replied by bibz87 on topic WebService Security
Also, is there a way for the exported spreadsheet to have "Type" and "Description" as columns instead of notes? This would make the Spreadsheet more readable.
8 years 5 months ago #3071
by bibz87
I just tried to make a Windows build (x86_64 Development build) and ran into this error:
The name `Google_Password' does not exist in the current context
error CS0103: Assets/I2/Localization/Scripts/LanguageSource/LanguageSource_Export_Google.cs(24,39)
Looks like Google_Password is within a #if UNITY_EDITOR but code that's using it isn't.
8 years 5 months ago #3072
Thanks for reporting this!
I added a fix to 2.8.7b4
Time to create page: 0.161 seconds
