Localization parameters don't get translated?
8 years 5 months ago #2984 by Frank
What do you think if we modify the code so that before parameters are injected into the translation, they check if there is a term with that text, if there isn't the parameter is injected, but if there is, then the translation is injected instead.
BTW, this change is now in 2.8.6a4
If a Parameter has a text matching another Term, then the Term's translation is used.
So that you can have terms like:
"SWORD": English=Sword, Spanish=Espada
"TEXT": English="You got a {[ITEM]}", Spanish="Tienes una {[ITEM]}"
If the Parameter text for "ITEM" is "SWORD"
instead of "Tienes una SWORD" now you get
English="You got a Sword"
Spanish="Tienes una Espada"
8 years 4 months ago #2992 by rtm223
Sorry for the delay in responding.
Just updated to 2.8.6a5 from the beta folder and my parameters are now appearing. Haven't checked the terms as parameters fix yet, but that should be super useful.
Time to create page: 0.163 seconds
