Help me(button)!!!
12 years 2 months ago #254 by truongson
Replied by truongson on topic Help me(button)!!!
Thank you very much. But can you give me details..How to set it up
12 years 2 months ago #255 by Frank
Replied by Frank on topic Help me(button)!!!
I attached an example with the script for localizing button states.
Just unzip the attached file in any project containing I2 Localization and NGUI with its Examples
Attachment LocalizationExtras.zip not found
In "Assets/I2/Localization Extras" I created a copy of the NGUI Localization example scene.
It now has a button at the top right with an image for each of the button states.
Also in the languageSource there are 4 new terms ("PLAY_BUTTON_NORMAL", "PLAY_BUTTON_HOVER", etc)
And I attached the LocalizeButton script to the button and set the names of the Term used for each state.
Thats it :-) by attaching that script and adding the terms, you will now be able to localize buttons with images for each state.
In future versions, I will add a propper custom inspector to easy the editing of that component and allow selecting the terms from a dropdown.
The following user(s) said Thank You: truongson
12 years 2 months ago #256 by truongson
Thank you very much ... I had success with the enthusiastic guidance of your
