Asset Seraliziation setting to: force text
- giorgiodeluca
8 years 9 months ago #2707
by giorgiodeluca
Asset Seraliziation setting to: force text was created by giorgiodeluca
hi,
if you set Asset Serialization setting to force text in the project setting / editor
(required to use unity with SourceTree for version management)
when I add I2 Localization 2.8.2 a5.unitypackage gives me error: Binary to YAML conversion: type SInt64 is unsupported
thanks
thanks
8 years 9 months ago #2721
by meganlfox
Replied by meganlfox on topic Asset Seraliziation setting to: force text
We've got the same issue. We have Asset Serialization set to Force Text (it's a requirement of Unity Teams, but it's also just needed to make Unity be ok in source control), and as a result, I2 Localization is dropping the error:
"Binary to YAML conversion: type SInt64 is unsupported"
when we import the plugin from the asset store. I have no idea if it's still safe to use anyways, but I seriously doubt it?
8 years 9 months ago - 8 years 9 months ago #2722
by meganlfox
AH HAH!
If you don't import Examples, this error won't appear. Which means the error relates to an asset in the examples, not anything in the main library.
So you can just click the checkbox besides the Examples folder to not import them with the rest, that will remove the error, and presumably the main library is then perfectly safe to integrate into your source control / project / etc. I'm uncertain what specific asset in Examples isn't importing correctly, though. Hopefully it isn't the localization db or something - I'm going to dig a bit deeper.
EDIT: It's the scene files in Examples/Scenes. Disable that folder, everything imports fine. I'm going to guess the dev had Unity set up in a way that generated scenes which now can't be converted to text assets.
Last edit: 8 years 9 months ago by meganlfox.
Time to create page: 0.156 seconds
