reference other keys
2 weeks 4 days ago - 2 weeks 3 days ago #3891 by topspin
reference other keys was created by topspin
Hi, I have this scenario.
level_up_x_y - Level up {x} to level {y}
where {x} maybe some character name
and {y} maybe a value
What's the best way to accomplish this?
Last edit: 2 weeks 3 days ago by topspin.
1 week 5 days ago #3895 by Frank
Replied by Frank on topic reference other keys
You should use parameters if you need to replace texts inside the translations:
inter-illusion.com/assets/I2LocalizationManual/Parameters.html
Or if you need more control, you can do a callback
inter-illusion.com/assets/I2LocalizationManual/Callbacks.html
Either way, you can replace the value inside the translations before setting them into the label.
